charge it whenever you can, a cycle is from 0% to 100%, so if you charge from 80 to 100% its not a cycle just 1/5 of a cycle
Read this:
http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
With Li-Ion, it is recommended that you charge the battery often. Also, try not to completely discharge the battery too many times as there's the risk it might not fully charge in the future. From time to time, it is also good if you do a calibration by discharging it completely and fully charging it while the device is turned off.
Any advise on the below?
i'm sitting with a puzzle charging my xperia C3. The original C3 charger doesnt charge my phone but it does charge my samsung tablet as well as ablackberry phone i use at work. no other charger charges my phone not even the sony cable plugged into my computer helps. funny enough my cable in an I-Phone charger charges my phone and charges it really quick too.
any info on this problem or any solutions please?
Regards
