Help
The mobile sony xperia c3 turned off and then restarted in safe mode. I followed the instructions and it did not work. I need to remove the safe mode right now
Ayuda
El mobil sony xperia c3 se apago y luego se reinicio en modo seguro. Seguí las instrucciones y no funciono. Necesito quitar el modo seguro ya mismo
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Just restart the phone, that should boot the phone in normal mode.
Hi @Damianmutte11, welcome to our forum!
As @uliwooly mentioned, a normal restart will remove safe mode, however if you should end up in safe mode again, make sure that your volume down key is not pressed during the startup of the device. For example, if you have a case on your device that is pushing the button down or that it's stuck, as holding down this button during the startup of the device, will make the device startup in safe mode.
Let us know how it goes!
dont worksthe Solution. Just is a copy paste from Internet. support only in english.. a shame
Hi again @Damianmutte11,
To start off with, as this is a Global user based forum, there are some guidelines regarding in what language we can provide support and that is English. If you prefer support in your local language, you can always get in touch with your Local support team.
Do I understand that a reboot will not exit safe mode for you? In that case, is the volume down button working as it should?
Keep me posted!
