After i update my c5 ultra to the latest version my front camera did not work . Ive try everything like restart or reset but still doesnt work . Pliss do somthing with the update .
Thanks .
What if you repair the phone with XC
Alternatives on How to backup Xperias
Hi @Aammiirr,
Welcome to the community,
Sorry to hear about this, before you run through with a Software Repair, make sure to backup the handset. I have supplied instructions below.
Let us know how you get on.
Good night maso Less One year I do not work the camera.frontal Since I dropped the Sony software ... I wanted to sable if someone could help me to solve this problem I already send a sony.msj Sony and me. answered
@Sabrinasantana me arisguo a contestar en espanol, la cosa es la siguiente: Si ya intentaste a hacer un software repair ( software repair using Xperia Companion ) y todavia la camara frontal no te funciona, el problema es seguramente hardware, o seal la camara fisicamente no esta funcionando. La cosa mejor que puedes hacer es hacer valida tu garantia contactando el soporte local en tu ciudad ( Local support ).
Si tu garantia ya expiro' pues mejor contacta Sony de toda manera, pueda que el modulo de la camara no sea tan caro.
