Hi, i want to ask something not so important but just to check if there is a solution about it, i updated my xperia C to 16.0.b.2.6 like many others did but i remember before the update when i was typing a sms i could insert a big variety of emoticons, symbols etc now after the update i can insert only few faces by clicking the smiley button so is there any way to recover the old emoticons? Thank you
open the messaging app > any conversation > tap on the input box > pull down the notification bar > xperia input settings
or
settings > language & input > Xperia keyboard > personalization guide
With all this process you mean that i have to check button smiley so it appears on keyboard?
yes indeed.
hmm yes but its not that im asking, i had done that just when i tap the smiley button so i can insert an emoticon in my text it appears only 25 emoticons, before the update when i had bought the phone i could see a big list of emoji, symbols etc like many kind of faces, or cars, or hands clapping, or a muscled arm etc 😛
lol for all that you need a different messaging app
nope i was just using the message application nevermind can you guide me at least how to format my sandisk micro sd card to FAT32 because i have the common problem "sd card removed unexpectedly" and i read somewhere that if i do that it solves the problem
oh lol wiki of course
ok thank you very much!
Anytime
