- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
So i hace the following problem with the Xperia C:
The data storage of the phone and memory card keeps overloading itself what i mean is that for an unknown reason it increasingly uses storage space without me downloading from my pc or the internet. The results is very little space becomes availible, files get corrupted and my phone slows down.
Phone Status: external storage 4GIG sd card (new san disc sd card), internal storage 1,2 GiG, phone was reset to factory settings about 8 hours ago and both memory areas formatted. AVG anti virus Pro Protected
Description of behaviour: I will plug the phone into my PC (which is virus free AVG Protected) the launch the Media go application and move some songs accross about 50, i will disconect my phone and play the music and very shortly after that when i access my phone to try play the music again the songs will jump in bit rate the rerepeat the last 2 seconds this is then followed by the phone swallowing up its own memory then i am left with almost no space on the phone and memory card with corrupt files.
Notes: I have only had the phone for about 8 days, only downloaded from apps from play store.
If anyone can please assist me as soon as possible
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No,the phone should work fine with cards up to 32GB.But there are some compatibility issues between the device and some micro sd cards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
http://www.sandisk.com/products/memory-cards/microsd/ultra-class10-for-android/
You can get a sandisk (16/32 GB max).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You will lose warranty if you root,but here you go:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
