Can anyone help me on how to edit my contact info on my Xperia C. Everytime i attempt to edit "Myself", it prompts that "Contact has stopped".
Please advise
problem.:smileysmileythumbsup:
If you uninstall Facebook and WhatsUp it should work. Make sure that you don't synk your contacts with Facebook if you decide to install Facebook again.
I think Facebook is the main problem, Do the following step:
from setting, accounts & sync settings then remove all accounts except gmail account.
phonebook well work, when I try to add facebook account again the problem appears again
I had remove facebook account and now my phone is working well
Thanks for the solution, it worked for me.
