Dear Sir,
Can we increase battery upto 3000mAh by replacing new battery ?
As Battery does not giving good backup while using Power Management.
So can you develop new battery with increase battery mAh from 2300 mAh - 3000 mAh for better performance.
Give any suggetion on this.
I am waiting for your reply.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Thank you for the feedback. I will forward this internally.
my xperia c is around 8-9 months old . I'm Having a problem that from couple of days when im charging my phone it get's charged upto 40-60% then suddenly the charging stop's nd when i connect other phone to they charger then don't get charged
I have Bought almost 3 chargers nd all of them have been burned from inside nd not only charger some time's the cable also dont work is it a problem of my phone or the usb connector built in the phone
