Anytime.
i got same ploblem. when i try to record video via snapchat, my phone freeze, then it
wont respon almost every input, it just respon home button n power key. then i try to open snap chat, and again my phone freeze. when i try to open camera, it show exactly same error message like deep11.
alrdy try to force stop snapchat, but still cant open camera app and it still showing same error message.
then after couple hour i got notification says that snapchat prevent stamina mode, it drain my battery.
i dont rlly sure if it happen bcz snapchat or not, alrdy uninstall snapchat but still got that error message. everything work normal after i reboot my phone, but it will error again when i do the same thing again.
pls help
I have the same problem, while using Snapchat. Any others apps work okay, only this one is making such problems.
Heelp.
