Ok,try settings-apps-all-camera,force stop and clear data. Restart and check.
There are 2 phases: focus and shoot. Half press will focus and start the flash, full press should take the picture.
Cool.
Hello, i am experiencing the same problem, i try to force stop and clear data, and restart, long press, anything. But still it doesnt work . Is there any method to fix this ?
