Just Bought a C5 Xperia and got update 5.1 lolipop, 2 days ago bought MBH20 to go with my C5, Using it its on phone calls is fine, but when I use it on Whatsup voice call it stop working, BBM voice call, Line same problem, I do not know it is the Bluetooth incompebility or something, I tried on my friends Sony Z3, it just works fine with voice call on whats up.
Did repairing the Software, but no help, I do not know whats wrong with it, anybody has the same problem? or any setting should I know about?
BR
Topic edited by Rickard
I'm sorry to hear that
Would it be possible for you to take a log file from your phone after trying to use the bluetooth headset for calls in 3:rd party apps and send it to me?
I will forward it internally to see if it's something that can be improved from our end.
To do this:
Settings > About phone > Build number, tap 7 times on the build number
Go back and select Developer options and turn on "USB debugging"
Restart your phone
Try calling using 3:rd party apps
Settings > Developer options, select "Take bug report". When the report is ready (takes a minute or so) tap the notification and share it to Google Drive and then send me a link in a private message.
Without a log from the phone, i'm afraid it's hard to say what the cause could be.
As you say, a possible reason is that another app is currently using it.
Ok i will do it now.
thanks
Hai Rickard,
I have sent my bug report to you please view it,
thanks,
BR,
I have forwarded your log internally but i don't have any new information yet i'm afraid.
I have sent you the link, is it safe to give the bug report? I dont know anything about this,
Please Advice,
