My xperia c3 ,drain very fast,80% shutting down
The battery is sometimes disconnected at 30% and sometimes at 60% and 70% at the time. It is assumed that the battery has remained at 0% and it is separated without any preconceptions. I need to walk the charger when the first thing is done.
GT
Sorry for my language in arabic
How can i apply safe mode ?!
My battery is turned off in half an hour i have to connected it with the charger 7 times or more in a day it turned off when gets 30% sometimes in 50% or 70% and i must charge the phone to start up again or it will be off alwayes how can i treat this problem ?!
I have already apply safe mode and the charge were 90% then i used my phone for 4 hours and it was good but when the phone get 55% in the safe mode it shut down again for low battery 0% what should i do ?!
Hi @Wafaa19
I'd suggest trying a software repair using Xperia Companion.
Let me know if the issue still remains after this
@Deva1927 wrote:My xperia c3 ,drain very fast,80% shutting down
Yes my phone battery problem
