- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
September 2015
September 2015
My brand new Xperia c3 had a estimated battery life of 5days but after using it for 2-3 days the estimated battery life is 1day and normal battery use with stamina is 13hours only. Why is this? And I'm running the latest update 5.1.1
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2015
September 2015
It happens when your phone is left overcharged so the readings are a bit off. Go into apps>all>Stamina/Eco and clear data then restart phone.
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2015
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2015
September 2015
You can reset stamina like this: first disable it, then go to settings-apps-all,scroll down to stamina app. Tap on it,force stop and clear data. Restart.
alexdon
