- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2013
October 2013
Hi, im planning to buy this phone....but the internal memory of 4gb seems too low for my usage pattern...so I want to kno whether there is any option to move apps to the sd card in this phone......i know this option was removed after ics...but in some forums I saw something like this...so I want a confirmation...
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
I am using this phone and option for moving app from internal to external sd card is possible
Goto settings. Apps. Select app. If its installed in internal memory then it will show the button to move the app to sd card
6 REPLIES 6
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
You can not move apps2sd, you will have to
root your phone
partition your SD card
install an apps2sd app
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
Are you sure rooting is required??? In some video reviews, I saw them saying about this feature in this phone.....
m.youtube.com/watch?v=ebPDAW9Sw1o&desktop_uri=%2Fwatch%3Fv%3DebPDAW9Sw1o
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
Try it if you want to but you need to root your phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
Thanks for all those replies....since u r using the phone, can u tell me ho is it?? Overall performance, battery,display and camera???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2013
October 2013
No rooting is required, Xperia C has App2SD feature but a personal advice do not buy this phone, its not worth it!
