Antenna Jump
Hello, please guide how many months you listen to the antenna jump, in fact, there is not a SIM card in the phone at all, the SIM card is active for a few hours, then it will take 2 to 3 hours later.
پرش آنتن
سلام لطفاً راهنمای کنید چند ماهی هست گوشیم پرش آنتن داره ،در واقع الان اصلا سیم کارت داخل گوشی نیست ،سیم کارت چند ساعتی فعال است بعد ۲ الی ۳ ساعت دیگه آنتنش میره
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm a bit confused, does the phone has a SIM card?
If it doesn't then are you referring to WiFi?
If it does then are you saying that you get coverage and then you lose network coverage?
سلام الان از طریق وای فای وصل شدم، چون گشی سیم کارت را نمیشناسد
Hi, I'm now connected via Wi-Fi because I do not know the sim card.
gT
