I am going to give a report of what happened with as much detail as possible.
Phone was working fine until suddenly i get a "Encryption failure" screen and it asks me to restore my phone. I then proceed to attemp to restore my phone using the Xperia Companion app for Windows, but after turning the phone off, waiting 10 seconds ( When it asks for 5 ), and turning it on while holding down the volume down key, i get to this screen. The Android logo with a open "Chest" and a explamation mark.
If i try to turn on the phone normally, it just gets stuck on a loop where the Sony logo keeps appearing. The animation that usually plays doesn't aswell. After reaching the "Red Triangle screen", i opened the menu pressing the Camera button and cleared the Cache as well as resetting the phone. Nothing worked.
Now, after some more time, i can't even get to that screen. If i try to turn on the phone holding the Volume down key, the Sony logo won't appear, the screen just stays black while the led blinks green, red, then it stays lit on green. If i keep holding the Volume Down, it just stays there, black screen with green led. After i release the buttons, the "Sony loop" resumes after a while.
It seems to my that my Android OS was badly corrupted somehow. Is there any way to do a clean install of the OS? If not, what can i do to fix this issue? as it clearly is a Software problem, not a hardware one.
Thanks in Advance.
