Hi
At this time it´s not possible to control the audio volume with gestures on the wf-1000xm3.
Is there a possibility for this feature to be added via a software update?
Hi, please note that this is the Italian Community.
You can try by downloading the Sony app "Headphones Connect" on your smartphone that allows you to change some functions related to the touch/gesture control features of the product. You can figure out if it works with the volume feature. Unfortunately I can't try for you.
