cancel
Showing results for
Search instead for
Did you mean:
Headset SBH20
SOLVED
heliortiz
New
Headset SBH20
Olá, gostaria de saber se é possível utilizar esse headset com SmartTV Sony, com tecnologia NFC?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.pt_PT.title
V57...
Contributor
Quer-me parecer que é possível...
http://www.amazon.co.uk/Sony-SBH20-Stereo-Bluetooth-Headset/dp/B00CZC71C6
"I use this daily to listen to music and take calls while I leave my phone in my bag. I also use this with my TV when I'm playing games and don't want to keep my wife up. After 6 months or so I've had no issues with it whatsoever. It is really easy to pair with devices, and it's simple design makes it a really versatile accessory."
1 REPLY 1
V57...
Contributor
