Partilhe a sua experiência!
The speaker battery has no charge, when I press "power up" it blinks 3 times (charge light). wich is expected behavior when you have no charge. The problem is that it doesn't do anything when I connect it to the power plug. The speaker doesn't power up or charge. There is no light in the charge light.
Hey parsxeal,
Check that the AC power cord is connected securely, or try a different main.
If the issue is still there, it will need to be sent for repair. You can use Sony's authorised service centre locator: https://bit.ly/3tMmxVC
