Partagez votre expérience!
Hy
do you know if it is possible to use the following combination (and how it works) :
SAL 300 f 2.8 SSM II + SAL14 TC + LAEA3
thank you
After a bit digging, I found this link for all the compatible lenses with this converter: https://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=eu&lang=en&mdl=SAL1... , so the lens is compatible with it, however, there are a few restrictions, click on the lens name to check it.
Also the LA-EA3 is compatible with the SAL300F28G2 but the functions restrictions depend on the camera you're using: https://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=eu&lang=en&mdl=SAL3...
Hope it helps
