Will my new sony KDL 40W 705CBU get youview in the future?
Other than this can anyone tell me if any updates are planned?
thank you
David
Hi there
Royabrown above is correct. Only Android based TVs are getting YouView and unfortunatley your model is not Android based. Also, Sony does not generally give a date on the next update? Why do you need an update? Is the TV not doing something it is supposed to do?
@carlan2uk wrote:Will my new sony KDL 40W 705CBU get youview in the future?
thank you
David
According to this description:-
this is is not an Android TV. So no, it won't get YouView 😞
As for other possible updates, I am not in a position to know one way or the other, I'm afraid.
Hi there
