When are Sony going to fix all these bugs.
1 Youview guide and catch up is now not working
2 Iplayer won't play in 4k with internet speed of 40.
3 Iplayer ITV hub etc doesn't save sign in details
I won't buy sony products again
Is this on software version 6.5016?
Yes that's right
Try going to settings - device preferences - Storage - Internal storage - cache - clear then restart the TV.
You can also try resetting the Youview settings by going to Settings - Apps - YVServiceHost - storage - Clear data and cache
I hope this helps
I have tried resetting storage cache to no avail.
I can't see YVservice host in app list. There is that much junk/settings that in my view should
be set automatically.
I would expect to see YVservice alphabetically between x & z ?
Also the bbc iplayer is not listed as recently opened app even though a program has been watched
fully for an hour.
And still the bbc app is asking for a sign in every other day or so.
A new software update was released at the end of last month (v6.5042) try updating to it and checking the apps again.
- JD
