Re KDL48 A9
This morning whilst using YouTube to check the weather forecast from the met office , I noticed that the "subscriptions" folder has disappeared from the folders list on the left side of the screen. I am still logged in and I have re booted the TV but no solution. Using my laptop, I can see that I am still subscribed to many.
Anyone had the same issue? Is this a TV matter or maybe YouTube or just finger trouble?
Maybe the app was updated and has a different layout? Can you share a picture of what you're seeing?
Here goes in trying to share an image!
Below the words "Gaming" there used to be "subscriptions".
Have you tried going through the Home tab and looking for Subscriptions?
If it doesn't come up, maybe try clearing cache and data for the app (under Apps - YouTube) and try opening it again.
Hope this helps!
- JD
