Hi all
When streaming from a device to the TV using the build in Chromecast the YouTube video is stuttery. I assume this is due to the internal Chromecast streaming at 60fps. On Chromecast 1 you can change the setting to 50fps however I can't find the same setting for the built in Chromecast. Is this available?
Hello @mobilyuk,
do you mirror your devices screen or cast the video to the TV via the YouTube app?
In the second case the TV would open the YouTube app and load the video itself - the framerate however is determined by which framerate the video was uploaded in - even then it would surprise me if there would be a noticeable difference between 50p and 60p content.
- Nic
