this comes up every 15-30 mins
all other devices are fine, just the TV. any ideas?
I fact I did not have the problem UNTIL I did a factory re-set, following contact with You View's advice when I could not see any info there in HD mode.
I did the reset
firmware upgrade
static ip on tv and router
none of this worked
sony need to just add a minor fix to allow you to suppress pop up network issues come on Sony. There’s about £36,000 of revenue on this single thread complaining about it!!!
Hi, what's the model that you've? Maybe I can help. Also what's the software version on your TV? Do you get the same error message as the others? Are you using Wi-Fi or LAN? sorry for the so many questions Just trying to be helpful. You may also check something called Android Core version if your TV is an Android. And check the time is right: Go to settings -scroll down to System Preferences- select Date & time -select Use Network Time.
Check your hub WPS is linking to your smart TV, by pressing the WPS on hub and at the same time, go to settings on smart Sony TV to make sure you are on the correct input settings by selecting Digital and you should be good to go
Wi Fi not connected issue still happening after 3 or 4 software updates factory resets and soft resets. Sony just give me the message its been escalated to our technical team.
Hey jgriffin14369, what model do you have? Did you try turning off IPv6?
Does this happen on a hotspot as well? Or if possible, wired vs WiFi or a different network of any kind?
