I have just bought a smart TV with youview and the record button does not work. After reading i am told you can not record from this TV which if known i would take it back. Can you plug in a you view box and use that or does anyone knoe how to get round it.
Regards Glen
@Glen676 wrote:<snip>Can you plug in a you view box and use that or does anyone knoe how to get round it.
Regards Glen
Yes, (in the UK) you can plug a YouView PVR into the tv via HDMI and use that to record terrestrial broadcast channels.
Hi Glen,
Can you let us know the model of your TV?
Thanks,
Sean Mc
You can record Freeview and Freeview HD content from the TV but not Youview. Also, I believe that to enable the record function, Youview has to be turned off.
