I have a XR-55X93J Gogle tv. After last software upgrade ver. 6.5660 I can't set screensaver timeout or turn screensaver of. These options just disappear in new version. I remember that I can do this before upgrade. There is no options in Living Decor app or Ambient mode settings. I listen some radio streaming apps and when screensaver kicks in after about 15 minutes radio stops playing. Any advice please?
Hey DarkoD, try to reset the TV to factory settings and test again.
I did that with no success. This is the version and the file name of the upgrade
ver. 6.5660, sony_atvotafull_2020_1605660100_eua_auth.zip
It seems that timeout and off option for screensaver are removed in this upgrade.
Hi DarkoD, maybe that's the case, you can contact Sony as it might be just a setting that got changed.
