At night when my tv is on, when I turn on a switch in a press the tv turns off and on, it does the same with a plug in the siting room as well. this only happens at night . Has anyone else encountered this problem. Thanks
Hi @Markie2012 It sounds like you need to get your home electrics safety checked as soon as possible.
Try to connect the TV to a different plug and see if it happens there as well, try to get the electrics checked as soon as possible.
