x
xh90 screen flickering problem
profile.country.LV.title
bycincik
Explorer
this problem only occurs with internal satellite broadcast. this error exists constantly. Every 10 minutes
please see the videos
https://streamable.com/fxwow2
https://streamable.com/0met46
5 REPLIES 5
profile.country.GB.title
Joe_Dohn
Specialist
Have you tried the basics of disconnecting everything (including the aerial/sat cables) and unplugging the TV for a few minutes?
bycincik
Explorer
I disconnected all cables connected to the TV. I unplugged the TV. I waited for 10-15 minutes. I made the connections again. i turned on the TV and the problem was still. then I reset the TV to factory data. I re-installed. but the problem still persists.
I just discovered that. when i turn motionflow feature off in picture settings, the screen works fine. there is no flickering on the screen. When I turn on motionflow feature again, the screen of the TV starts to flicker again.
Joe_Dohn
Specialist
Have you tried updating to the latest software version?
bycincik
Explorer
yes. latest version installed.
Joe_Dohn
Specialist
Try disconnecting the aerial/antenna then do the tuning without it (this resets the internal tuner) then try tuning it normally again.
Hope this helps!
- JD
