Apart from the addition of eArc and the motion enhancer, what's the better telly? I don't need eArc right now... Is there much problem with the edge lit led on these TVs?
You may not need eARC right now, but how long do you plan to keep this set for?
Good point, I'm going to be keeping it a long while. The sound bar I'm going to get doesn't do dolby atmos though.
