Is there any way to adjust motionflow on non native sony apps? I can only adjust it on native media player, netflix and watching tv. In any other apps it says that is unavailable.
It is happening on custom apps like MX player, VLC player etc. Native media player, Netflix and youtube are ok. Smoothness and MOtionflow are locked. Smoothness is locked to 3 on vivid picture settings.
What's the problem with using the native app if it works? I'm not sure why this is happening but it could be a compatibility issue. Have you tried a factory reset just in case?
Yes, i also did a factory reset. Didnt fix the problem, i also did all the updates. I dont use native apps because if i plug an HDD it takes long time to index it...
Hi mtampou, on the third-party apps that you download it's not guaranteed that all the settings will work.
