I have downloaded the firewire update onto a USB, I have plugged it into my TV and it recognises the update file is there but then tells me "TV cannot update via this usb stick" any suggestions?
I have tried this already
Try to unzip the file with WinRAR or, restore the TV to factory settings (after an update it is still suggested by Sony).
No still getting the same message
This link seems to have done the trick. Thanks for your help bud.
It seems to be stuck in a loop. Getting to about 20% then restarting the TV and going back to the start. Is that normal?
No it is not normal, wait and if nothing change unplug from the socket for a few minutes...
