The above tv keeps getting the WiFi not connected pop up after installing Oreo. Lots of people reporting same issue on other forums and other Sony TVs too. Not sure if connected but most people with XF9005 have a Sky Q hub. Can it please be looked in to.
i have had the same e-mail at least six times in the last three months it looks like a stock e-mail that sony send out as every e-mail is worded the same
As I've said, I connect my VPN over IPV6, hence I need it
sony are now saying that you dont have to disable vp6 as the fault is on the tv
I've updated to PKG6.6555 and it seems even worse for getting the message and dropping wifi.
So Sony have told me to disable IPV6 on the LAN side last week on my sky router. Since I've do that I've had no wifi drop out or wif not connected message which is good. I have told them this and all they said was we are pleased it has solved the problem and disabling IPV6 wont cause any issue/malfunction. No mention of a future update.
