- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi everyone,
Today, i installed the newest FW:PKG3.865.0136EUB. This could be (maybe) tho follow up of my question: "4K streaming on XD9305 via NAS..lags...impossible"
I'm sorry, if i post my issue at the wrong post/section.
Well...i do have one less issue: voice controll is back
But, there is a strange behaviour: if I connect to my AC WLAN (5Ghz)...
- it shows connected
- the router shows also connected
-=> but no connection to my NAS or any other device! That's a new feature, because with the older FWs all apps were able to access&use my NAS ( except Sony's Video app?! )
==> if I connect to the 2,4Ghz old fashion WLAN all apps are able to access&use my NAS ( except Sony's Video app?! )
- wired connection is of course still there and unusable due to the 100Mbit interface
What I did:
- FW update
- manual restart of TV & apps and router and NAS => no change
- tests with 4 other devices on the 5Ghz AC WLAN: all are working fine as expected
Is there anything else i do have to do after the FW update?
Thanks for all the advices & ideas
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Considering that you have updated the firmware, I would advise you performing a factory reset. Many times this can fix issues. Instructions HERE.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Quinnicus,
Thank you. Yes, that was the step, i did not do. Now, the apps are able to see the network devices via 5ghz (except Sony's video app).
For the other problems, i'll open new posts
Thanks once more,
Henrik
