hi there,
Is is possible to add a 1Gb network adaptor to the XD93 via some kind of USB NIC?
My understanding is the XD93 has a 100mb card, which is not sufficient to handle 4k content from an remote share.
Thanks
Hi there
No it isnt possible - you have no way to install the relevent network drivers onto the TV - hence will fail.
