hi , after upgrading to android 7, HDMI RANGE picture settings IS MISSING , so cant cant select rgb full or limited , tv looks grey now , colours are not good when playing ps4 , please help ? thanks
Hi there,
I would recommend performing a reset of your TV. You can find more details on how to perform this here.
Let me know how you get on?
Cheers,
Sean Mc
50w808c here same problem
perform a factory reset doesn't work.
hi there , nougat on later sony models have video options in advanced picture settings, but after our tvs ( 2015) nougat update, VIDEO OPTIONS is missing under advanced picture settings , factory reset hasnt helped , its not their across all 2015 , early 2016 tvs, tried with my w755c too , its not been implemented , please help
