Today I decided it was time to update to Android 12. Now I deeply regret my decision. All TV functions (picture mode, sound output, channel selection etc) stopped working. Only apps work. I can't watch watch broadcast TV either. No Freeview, no Freesat. Any attempt to use these functions and all I get is either no response at all or a second or two of dark screen and back to Home.
Has anyone seen this behaviour? I'm desperately trying to avoid resetting the TV and lose my configuration, end up in a worse place, or both.
Thanks.
the amount of things that have gone wrong for me after this update is becoming really upsetting. after three years of everything mostly being great, this tv is now a massive cause of stress.
sometimes a reboot (long press power button > restart) gets the HDMI inputs working normally, sometimes a power cycle briefly solves other problems.
i did do a factory reset after the new update introduced these faults, and everything was fine … until it updated again. I assume a factory reset uses an older system image onboard, I didn’t check the version numbers.
Help > Status & Diagnostics > Self diagnostics says everything is fine, which it clearly isn’t.
Honestly, this is exasperating! This has been going on for two months now, Sony must know about it!
