Hi there. I've ordered the x85c. Please can you tell me if it has an integrated webcam?
Also will apps like Spotify and Skype be pre-installed?
Thanks
Jonny
It looks like this model does not come with the camera integrated.
Thanks
What are you sources? Like I said it's not in the spec, though I read it does have face detection?
I don't know the UK related site address but if you understand a littel italian you can have a view at the detailed spec here infoprodotti.sony.it/contents/instance1/files/document/2887KDX8505C.pdf
Face detection is per image processing not for looking at you
