Hi all, this just appeared in the last hour, a small dark dot that is under the screen and is very visible in most viewing.
Any ideas? I have had many issues with the panel since with got it, so i finally have to call Sony and be without a TV for ages??
Hi there
Are you able to take a couple of photos and post them here? Also please reply back with the full model of the TV.
Its hard to know what it could be - As its only just happened, id rule out an insect. Dead pixels?
