- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
X8305 Questions?
Purchased the 49x8305c which arrived yesterday. All set up (I think) and very pleased so far.
I do have 2 questions though
Firstly I've got a Sky Plus in HDMI 1, PS4 on HDMI 2 and Sony Blu Ray Player on HDMI 3. Because I'm a bit OCD, I went straight to input settings and set labels for all 3. However when I pull up the input list I notice the TV recognises the PS4 on 2 and the BR Player on 3 as they are both Sony, so it creates duplicates. So I then went into the list and chose to hide the 2 I'd created, but then I notice that both versions had now disappeared from my input list. So it seems I have to have those 2 duplicated. is there a way around this?
Second question, I think I know the answer to, but I can't integrate my Sky Plus into this can I? Because it's a twin tuner and this is only a single input for satellite? So my Sky Plus has to come through the HDMI? Is that correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi therr
The duplication of HDMI sources has already been reported:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2047983#M35186
But this is just a minor annoyance and does not effect the running of the tv.
To get Sky, you kust use the sky box on a HDMI input.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Right I see, and there's no newer updates than that? I appreciate it doesn't stop them working, maybe I'm just a bit OCD!!
And I thought as much for the Sky. So the digital satelite input is only for Freesat presumably?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To be honest, the satellite input is mainly for use in other EU countries with the use of a CAM module. Its kept for uk market. BBut ultimately the TV is Freeview only, not Freesat hence a basic EPG.
