x83 Bravia 2015 - Apps crashing
SOLVED
DomDee
New
Hi All, 1st post!
I got the 43x8307c a few days ago.
All my Android apps, video, album, Netflix and youtube are crashing after about 10 mins.
They play fine then close down and tv returns to the digital channel or tuner mode.
Anybody getting the same problem? Is there any known fix?
Thanks DD
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
DomDee
New
SOLVED
HOME > Settings > System Preferences > Retail Mode Settings > Picture Reset Mode = Off
Picture reset mode does two things after 5 or so minutes;
  1. Resets the Tv back to Tuner mode or basic TV channels if you are in Home or Apps etc
  2. Outputs the sound at a different preset level
I had both these issues and was going to return the TV to the seller as 'not fit for purpose'.
Glad I found the setting and didn't have to return it...
DD
2 REPLIES 2
DomDee
New
SOLVED
DD
profile.country.GB.title
jumpsuit
Expert
Welcome to the Community @DomDee :slight_smile:
Thanks for letting other members know the solution you found :wink:
