x
***** with KDL-55W756C
Haradrim
Explorer
Hello Everyone
Some strange problems which Iam monitoring last months on this TV KDl-55W756C,
1. reaction of infrasensor from remote controller - its doing randomly, sometimes not responding and Iam pushing and TV doesnt respond but sensor is still flashing. I have to control TV manually with buttons behind TV.
2. when I want to rewind video (.avi.mp4....) for example forwarding - I HAVE TO STILL HOLDING THE BUTTON OMG, because when the button is only one time pushed, it forwards 15-20 sec, so very funny when I want to forward all the film, holding button 5 minutes
3. after last upgraded firmware my WiFi connection lost, TV cannot find my network or another networks nearly, on router is everything allright, normal connected with another devices.
I want to ask, are somebody in SONY solving these problems or it is forgotten and this what I wrote is OK? and I WASTE 1 000 euro
THANKS
2 REPLIES 2
Anonymous
Not applicable
Hi there
Question 1
Try rebooting the TV - switch it completely off from the power point.  Failing that if it occurs all the time, do a complete factory reset, can cure many issues.
Queston 2
Try using Kodi instead of the Video app?
Question 3
Reboot you router and see if it then picks up the SSID.  If it doesnt, try changing the Wifi channel on you router.
Haradrim
Explorer
1. ok maybe I will try factory reset but will I have to setup up and load all channels?
2. never heard about it. I will try
3. everything seems ok as I said other my devices normally see SSID and are connected/disconnected
thanks
