Hello there, just got my telly on wall and iv put a wire straight from router to the telly and it's saying there's no connection, already connected to wifi? any help would be great thanks
Hi there
Your TV is already connected to your home network via Wifi - to use a 'wired' connection, disconnect from the wifi SSID (i.e. forget network) and re-do Network setup via "Wired" instead.
I turned the wifi off all together when I tried it, should I still forget network and leave wifi on you saying and thanks for the reply
Yes - Forget Network.
I am also on a wired connection - I have left Wifi switched ON - but not connected to any SSID and can confirm that I Still cast via YouTube and Screen Mirror via Wifi-direct (which is also set to on).
Im referring to your other thread:
https://community.sony.co.uk/t5/android-tv/lost-an-option-to-view-of-ipad-and-smartphone/m-p/2249223
Thanks have got the YouTube thing sorted will try the wires connection now, appreciate your help
Tried forgetting the network and it's still not finding, have got wire in the "LAN" bit on TV and in the second port on my router and no joy
Hi there
Well that is most disappointing 😞
A couple of suggestions:
