I see that the XJ90 remote has extra shortcut buttons for Disney+ and Prime video.
Will this remote work on an XH90 which only has 2 shortcut buttons?
If so can I buy the XJ90 remote separate and from where please, does anyone know the exact model?
Thanks
Hi @MrQwerty111
According to the specifications of the X90J the European remote is RMF-TX520E.
As this is a community of customers I doubt if you will get a definitive answer but as Amazon lists RMF-TX500 as similar I would have thought that the chances are good. However if the extra shortcut buttons work it is a case of try and see. The advantage of buying from Amazon is you can always return it for free.
https://www.amazon.co.uk/Commander-RMF-TX520E-100995321-1-009-953-21-RMF-TX621B/dp/B09579SYXB
Of course, that remote is only sold using Amazon rather than by Amazon. For the OP, did you manage to get a definitive answer?
I still think they would return fine, but as you say I prefer sold and delivered by Amazon, saves hassle for returns and payment refunds.
I haven’t ordered it as it’s £50 for 2 extra buttons, so will just see how goes for now.
