I am thinking of buying the Sony Bravia KD43XG8096BU. But want to know if it will get a firmware upgrade later in the year to get Airplay2. I Will look to another model or made if this TV will never be upgradeable to use Airplay2.
thanks in advance if someone can tell me if KD43XG8096BU will get a fix to enable Airplay 2
I have also asked this question of Sony UK but not had a reply so far.
Airplay2 support will be available from XG95 onward, not on XG80. You can still install from playstore thrid party apps in order to support airplay features on any android tv
