- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
May 2016
May 2016
wifi dropped on 43X8309C
I have the latest firmware 3.395 and after some weeks of use the wifi has dropped and a scan for networks does not find any. However, my wifi is working ok on a tablet if I place it near the tv so the signal is not the issue. This suggests the Sony software is not working properly for wifi. I also have a remote touchpad which has lost connection at the same time.
Should I do a restart or intial setup again ?
2 REPLIES 2
Anonymous
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2016
May 2016
Hi there
Yes, by all mean do a factory reset, as it can fix many issues. However others are also reporting network connectivity issues too.
See:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2148553#M42555
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2016
May 2016
Thanks Quinnicus - the soft reboot worked
Cheers!
