Is it possible to widen the legs on the Bravia KD-55XG8196? I’m looking at purchasing the Bose Soundbar 700 to go with the tv mentioned, however as it stands I don’t think it will fit on the tv stand along with the tv?
Many thanks,
Paul
Hi @Pippo505 you cannot change or modify the pedestal of your tv, but you can buy on the market any pedestal VESA compliant the fit your purpose (or buy a base on which to put the tv over the soundbar)
Hi @rooobb , many thanks for your quick reply. I have been having a look at the pedestal option, with so many options I’m being selective in which one I go for, the other option is a smaller soundbar!
Thanks again for your reply
I'd go for a different pedestal solution than choosing a smaller soundbar... the wider the speakers distribution the wider is the sound range it can deliver...
