Hi, my Sony KD49X830xC keeps disconnecting and then immediately reconnecting to the Internet (wi-fi). Signal is good (91%) and I get no issues with sky or laptops or iPads on the same network. Any ideas?
Hi there
Try changing the wifi channel in the router settings - its been known to help.
At the end of the day though, my advice is to always use an ethernet cable (not wifi), if you do alot of video streaming on the TV.
