As Kodi 19.0 is not satble yet, users are encourged to reinstall Kodi 18.9 version. As Google Play Store (which matches your device and the software to be installed) offers only the latest instabil Kodi 19.0, you need to install older versions manually. The question arises: which type of Kodi 18.9 (an APK file) can be installed manually? 32 bit? 64 bit? or x86? My device is an KDL-43W807C Sony Bravia. Can any one help me? Thanks
Csaba
As far as I know, the different versions can be summed up as;
Hope this helps!
- JD
Thanks for the replies. I conclude to try to install Kodi 18.9 armeabi-v7a Android 5.0+ nodpi to my Sony Bravia TV set.
Regards,
csaba
To my knowledge there's no such difference for APK files.
This usually only applies to Windows computers.
I sideloaded a backup apk from my mobile (32 bit ARM)
Hope this helps!
- JD
Thank you for marking the thread as resolved and listing the version you're going to use as well.
It'd be even more helpful if you have the time to provide an update after installing (whether it worked for you or not).
- JD
