Hi there - there is an excellent Android App that links my Sony TV to tvheadend's presentation of Sat-IP channels which works very well apart from a couple of issues that seem to be Sony specific.
https://github.com/kiall/android-tvheadend/issues/92
https://github.com/kiall/android-tvheadend/issues/104
Is there someone in the community or at Sony that can offer any help with these?
@Anonymous ?
Hey,
I'm the developer of that app, @stevellion let me know he had posted here
So - Sony Android TV seems have some bugs which other Android TV devices don't exhibit, e.g. this channel sorting issue, I've been trying to find a way to report issues to Sony without much luck so far!
Where and how is the correct way to reach out to Sony and report issues for Android TV? I can't seem to find anything 😞
Thanks!
Kiall
Hello both @kiall.macinnes @stevellion
At current there are a couple of lists of issues :
UK : HERE
Germany : HERE
Please note, these are not exhaustive lists - Issues are added to the lists where multiple people have complained on these forums. Sony is fully aware of the channel sorting issue - which is still an issue on the upcoming 'Marshmallow' update too.
So how to report issues. I guess there are two ways.
Hope this helps
Edit - If its a specific issue (i.e. app dev issues), I would suggest the online contact form. If is a more general issue with the TVs (lip sync, tv channel sorting etc) - possibily post it on the forums - for others to also view/confirm etc.
