I am very confident that XF90 won‘t be updated to support eARC.
Where is the confidence coming from?
This is my first Sony set and I believe that it will be my last if they do not upgrade their sets appropriately when there is a simple firmware upgrade available to massively improve the performance of the audio, the set is in this years range still and by far their best seller over the last two years so to leave it behind like that would be ridiculous frankly
Sony has never announced eARC for the XF90. The feature is reserved for their MT5893/X1 Ultimate based products. Even if it was theoretically possible, you usually do not get things for free from Sony. They rather take features away from you, like for example the Opera TV Store or the Video & TV SideView app in the past.
That doesn't put much faith in the brand for me
If the set got e-arc then I would have bought one of thier compatible e-arc products ie xf9000 or upgrade my onkyo AV to the Sony 1080 AV but certainly not now if you do not get the appropriate updates
